REG : Authorization code
Answered Question
Apr 6th, 2008
Hi ,
System Verion :CCM 5.1.3
System Architecture: 1 Pub 2 Subscriber
For accounting Purpose we need to give different Authorization Code to the users having international dialing access.
As far as i know Authorization code for outgoing calls can be configured on international Dialing pattern ..but how can i confiure a different Authorizaion code for Different managers. In our organization almost 200 managers, iam not able to figure out how to do map different authorization code for each manager using same international dial pattern.
Please guide?
Rgds,khan
Correct Answer by Rob Huffman about 9 years 1 month ago
Hi Khan,
It is important to remember that the FAC Codes are not entered against a user in the user or device profile in CCM. Once the code is created it must be given to the user and is not to be shared (much like a PIN or Password). These FAC Codes are created but not linked to the Manager anywhere in the Database so you will need to keep a reference in excel or some form of documentation.
Adding Forced Authorization Codes
After you design your FAC implementation, you enter authorization codes either in Cisco CallManager Administration or through the Cisco Bulk Administration Tool (BAT). Consider using BAT for large batches of authorization codes; the comma separated values (CSV) file in BAT serves as a blueprint for authorization codes, corresponding names, and corresponding levels. For future reference, make sure that you update your dial plan documents or keep a printout of the CSV file with your dial plan documents.
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Rob Huffman Sun, 04/06/2008 - 08:24
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Khan,
You are almost there :)
The FAC Code is not applied at the Route Patern Level, the FAC for the individual managers will include the **Authorization Level (for each Route Pattern) which allows International Calling. So you can create many codes that have references to different Authorization Levels.
To implement FAC, you must devise a list of authorization levels and corresponding descriptions to define the levels. You must specify authorization levels in the range of 0 to 255. Cisco allows authorization levels to be arbitrary, so you define what the numbers mean for your organization. The Authorization level is what is applied at the Route Pattern Level.
Enabling Forced Authorization Codes for Route Patterns
Perform the following steps to enable FACs for route patterns:
Procedure
Step 1 In Cisco CallManager Administration, choose Route Plan > Route/Hunt > Route Pattern.
Step 2 Perform one of the following tasks:
•To update an existing route pattern, enter search criteria in the Find and List Route Pattern window
•To add a new route pattern, refer to "Route Pattern Configuration" in the Cisco CallManager Administration Guide.
Step 3 In the Route Pattern Configuration window, check the Require Forced Authorization Code check box.
Step 4 In the **Authorization Level field, enter the authorization level for the route pattern. The number that you specify in this field determines the minimum authorization level that is needed to successfully route a call through this route pattern.
To add a small number of authorization codes in Cisco CallManager Administration, perform the following steps:
Procedure
Step 1 In Cisco CallManager Administration, choose Feature > Forced Authorization Code.
Step 2 In the upper, right corner of the window, click the link, Add a New Forced Authorization Code.
Step 3 Configure the authorization codes by using the configuration settings in Table (Below)
Configuration Settings for FAC
Authorization Code Name
Enter a unique name that is no more than 50 characters. This name ties the authorization code to a specific user or group of users; this name displays in the CDRs for calls that use this code.
Authorization Code
Enter a unique authorization code that is no more than 16 digits. The user enters this code when the user places a call through a FAC-enabled route pattern.
Authorization Level
Enter a three-digit authorization level that exists in the range of 0 to 255; the default equals 0. The level that you assign to the authorization code determines whether the user can route calls through FAC-enabled route patterns. To successfully route a call, the user authorization level must equal or be greater than the authorization level that is specified for the route pattern for the call.
Step 4 Click Insert.
Step 5 Repeat Step 2 through Step 4 to add all authorization codes.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803f3af7.html#wp1052254
Hope this helps!
Rob
ciscotech4u Sun, 04/06/2008 - 08:54
dear Rob,
thanks. i create Authorization level 10.and give authorization code as 665577. works fine for outgoing internation call. No issues.
but my problem is , there are 200 managers and company wants to give different authorization code(password) for outgoing international calls. as i have a single Route pattern for outgoing international calls how i will map 200 authorization code (passwords) for single route pattern ?
do i need to configure under each managers Phone settings ? but there is no such settings as i am lookign right now..
i hope i am clear about my issue.
Rgds,khan
Correct Answer
Rob Huffman Sun, 04/06/2008 - 09:17
  • Hall of Fame,
    Founding Member
Hi Khan,
Hope this helps!
Rob
Rob Huffman Sun, 04/06/2008 - 09:45
  • Hall of Fame,
    Founding Member
Hi Khan,
You are most welcome :) I have always thought that this process would be much better if the FAC were actually entered against the User Profile in CCM, but maybe someday.
Take care,
Rob
