Phone Directory missing after Upgrade 4->6
Apr 6th, 2008
after upgrade from Version 4 to 6, on the Directory Button no Phonebook appears. How can i configure this?
(Also the Help Sites on Callmanager not displayed)
regards
Ronny
Overall Rating: 3 (1 ratings)
Jaime Valencia Sun, 04/06/2008 - 10:39
go to the enterprise parameters and change the directories, help, etc URLS to IP instead of hostname, then reset all the phones so they take the change and try again
javalenc
if this helps, please rate
entireerfurt Sun, 04/06/2008 - 11:34
Hi javalenc,
thanks. What the default URLs of CCM so i have to change this?
cu
Ronny
Jaime Valencia Sun, 04/06/2008 - 13:25
i'm home and i don't have my servers available but all you need to do is go into system -> Enterprise parameters and there will be a bunch of URLs, directories, help, etc.
usually when you install your system they will point to the hostname of your server
ie
http://javalenc/...
just change the javalenc (imaginary server hostname) to the server's IP
http://x.x.x.x/...
it's the best practice to use IP and not hostname to avoid relying in DNS for this
Directories Button
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/5_1_3/ccmsys/a08ipph.html#wpmkr1032553
javalenc
entireerfurt Tue, 04/08/2008 - 07:21
Hi Javalenc,
great Tip. It was a Problrm in name translation. I changed the Hostname of Callmanager in this IRLs to the IP and it works fine.
Do you have any Ideas to the callmanager Helpside inside? This Sites also does'nt work.
Where can i change this sites resp. troubleshoot this.
regards
Ronny
entireerfurt Tue, 04/08/2008 - 07:40
In Callmanager Administration Website i tried to click the HELP Button or Link and and Tomcat Error Message Appears: This Site isn't found.
ciao
Ronny
entireerfurt Tue, 04/08/2008 - 08:00
ciao
Ronny
entireerfurt Tue, 04/08/2008 - 08:01
ciao
Ronny
entireerfurt Tue, 04/08/2008 - 08:30
this Bug-ID is not available to customers.
Sorry for several replies...
regards
Ronny
