Port Forwarding
Apr 6th, 2008
Alright, I just don't understand Cisco port forwarding. I have a 2610 with a NM-1E and I want to setup port forwarding. I have the router configured and it works great, but now I need some ports configured.
The way things worked on my old router, I had a DMZ setup forwarding all to one IP, but I also had some individual port ranges setup as well. SO:
DMZ to
9300-9399 to
9400-9499 to
9500-9599 to
etc, etc.
Is there any way to do this on the Cisco router?
Also, on my Linksys, if I attempt to connect to the external IP from behind the network, it would simply pass the connection through port forwarding as if it had been external. I used the following command to configure what I think was a DMZ, but I can't connect to the "external" ip from within the network...
ip nat inside source static 65.41.113.xx
Collin Clark Mon, 04/07/2008 - 08:30
To do a port translation on a router-
ip nat inside source static tcp [inside IP] 80 interface [outside IP] 80
Let's assume your DMZ address is
ip nat inside source static tcp 9300 9300
ip nat inside source static tcp 9301 9301
There is no way to do a range, so you will have a NAT statement for each port. I have not found a way to access the external IP from the internal network (yet). Don't forget to add/change your ACL's to allow the traffic.
