Calls going to Help Desk VM fail
Apr 6th, 2008
Hi, I've set up a Call Redirect to enable callers to leave a general message for Help Desk but the callers hear general Unity greeting. How can do I point callers of Trigger to Triggers VM?
CCX5,CCM5.1
Cheers
Rich
Rob Huffman Sun, 04/06/2008 - 14:32
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Rich,
Hope all is well :) If you are making it to Unity then the problem is probably not with the script. Have a look at the references from Vishal @ Cisco in this thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc026ac
It's likely that Unity is seeing the wrong CLID (as compared to the mailbox # for the Help Desk) or lack of a Routing Rule.
Hope this helps!
Rob
richb1971 Mon, 04/07/2008 - 01:08
Hi Rob, I good thanks.
Thanks for reply. It does help. I think your right-it is a CLID problem. I've created a mailbox for 1234 which is also the same number for the ICD trigger. User can jump off the Q with Menu 1 but Unity default greeting is heard. I've looked on Unity Call Viewer and can see my call: The dialled number is 1000 and the forwarding station is 1000 (1000 is Unity).
How can I change to point call at 1234 mailbox?
Cheers
Rich
richb1971 Mon, 04/07/2008 - 04:20
I got it. Needed to change the CLID on the script
Cheers for help
