same security levels on 2 interfaces on ASA 7.x
Answered Question
Apr 6th, 2008
If i have 2 interfaces with the same security level on ASA running 7.x code, with " same-security-traffic permit inter-interface " enabled and also an acl in place on both those interfaces, will the implicit permit be still effective between the same security level interfaces or will the acl take effect ?
thanks,
Vikram
Correct Answer by JORGE RODRIGUEZ about 8 years 9 months ago
no it will not, the command will bypass ACLs, in other words acl has not precedence over the command.
Overall Rating: 5 (1 ratings)
JORGE RODRIGUEZ Sun, 04/06/2008 - 12:57
Vikram, one of the purposes of same-security-traffic permit inter-interface command is to allow communications between interfaces with same interface security level without the use of access lists, so if this is what you are trying to accomplish then any permit rules between these same security interfaces can technically be decomissioned as this command will permit traffic between the two.
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/s1_72.html#wp1289167
Rgds
Jorge
vikram_anumukonda Sun, 04/06/2008 - 20:00
this answers part of the question, but what if i have "same-security-traffic permit inter-interface" and access-list configured on the interfaces with same security-level,
Question: will this make "same-security-traffic permit inter-interfae" command ineffective ??
thanks,
vikram
Correct Answer
JORGE RODRIGUEZ Sun, 04/06/2008 - 20:08
JORGE RODRIGUEZ Sun, 04/06/2008 - 22:06
Vikram, I am glad I was help to clarify your question, I thank you for using the rating system as it encourages all participating in forums to go the extra mile.
Rgds
Jorge
