Mapping drives not showing any folders/files when connected via CSD.
Apr 6th, 2008
I can successfully connect to my ASA using CSD and I can also map drives. However, I do not see any files that should be in the share. I try to create a new folder, which is allows, but it does not show in the folder on the local computer.
Name resolution works fine after I added a WINS server. I can connect to servers via RDP. I tried to use a domain account when mapping the drive. Net view does work to the PC/server after I have mapped a drive. I am running out of ideas of how to fix this. Also, I am authenticating against my domain controller. It does work fine over IPSec (which is a different policy). I will double check to see if there is a difference between the two.
Any ideas would be helpful.
TIA.
Dan
deyster94 Mon, 04/07/2008 - 18:40
I got it fixed tonight. I installed the lastest CSD (ver 3.3) image and it cleared up problem right up.
