Protecting the WAN interface
Apr 6th, 2008
I have a Firewall,whose Outside interface is connected to a ISP with a Public IP address,now I want to protect this Outside interface.How can I do this?Basically it is like a Hardening the Firewall or a Router which is directly exposed to global network.
Please help me.
Thanks and Regards,
JORGE RODRIGUEZ Sun, 04/06/2008 - 23:06
Your firewall is already providing perimeter security but you may still provide another layer of security protection in your edge router facing internet, I personally use the examples provided in these links.
thotsaphon Sun, 04/06/2008 - 23:56
Hi Venkat,
Actually your firewall already provides functions to protect a outside interface.As you know,Traffics originating from inside should be allowed by a firewall. It will deny all traffics originating from outside unless you want to allow them.One thing when you enable IOS firewall on a router you need to manually configure an acl to deny traffics from outside-to-inside.
Hopes this helps
Lavanholy Mon, 04/07/2008 - 01:35
Hi Thot,
Thanks a lot for the info.
Best Regards,
Lavanholy Mon, 04/07/2008 - 01:34
Hi Jorge,
Thanks for the info.It helped me a lot.
Best Regards,
