Designing Cisco ASA 5510
Apr 7th, 2008
I'm responsable for an permiter design with one of my customers.
The situation i designed it is included in the attachement.
The question i have is. I have 4 interfaces on an asa 5510, First line of defense and we need 2 dmz zones. I can use 1 interface for provider connection. 1 interface with the perimeter netwerk. Can i use 1 interface for a redundant perimeter connection and 1 for a redundant provider connection. Or are the 2 interfaces left necessary for the dmz connections?
Overall Rating: 4 (1 ratings)
Collin Clark Mon, 04/07/2008 - 09:13
  • Purple, 4500 points or more
It is possible, but a little messy and it would be a pain to troubleshoot. Each server in the DMZ would need multiple NIC's and static routes.
Can you do it this way? 3 Interfaces (OUTSIDE, DMZ, INSIDE). OUTSIDE to DMZ would traverse the FW and traffic from DMZ to INSIDE would also traverse a FW, but it would be the same FW as OUTSIDE to DMZ. Is that OK? If not you'll need a second set of FWs.
jorg.ramakers Mon, 04/07/2008 - 22:59
Is it possible to create subinterfaces (different Vlans)
As the DMZ is in the perimeter network, and it is between the Flod and Slod?
Best regards
Jorg
Collin Clark Tue, 04/08/2008 - 05:55
Yes you can create sub-interfaces. Not sure what you mean by Flod and Slod.
jorg.ramakers Tue, 04/08/2008 - 06:33
Hi sorry,
flod = first line of defense
slod = second line of defense
Collin Clark Tue, 04/08/2008 - 06:39
I originally thought of sub-interfaces and it will work, but I would suggest against it. It will b hard to document/troubleshoot. What are the requirements? Traffic must flow across different interfaces?
jorg.ramakers Tue, 04/08/2008 - 06:46
I need to configure 2 different dmz zones. And both of the dmz should not communicate with each other. i only heve 4 interface 2 for redundant isp and 2 for redundant connection to the dmz switches.
Best regards
Jorg
Collin Clark Tue, 04/08/2008 - 07:03
So would my suggestion in my second post work?
jorg.ramakers Tue, 04/08/2008 - 23:29
Yes, It can work, i was hoping someone else would have another idea as you are suggesting against subinterfaces
But will rate your post.
Jorg
