Call Manager 6 + 1760+ Call Back over PSTN
Apr 7th, 2008
Hallo All,
i configure my call manager for "Call Back". Its work in may network. But now i try to configure this for subj. How i can do it?
My 1760 ist configured as H.323. And has 1 x E1 to PSTN.
smalkeric Fri, 04/11/2008 - 10:40
Are you facing the issue with E1 connection. Just chek if the Extended function inthe callmanager services are up and running
alexander.keise... Fri, 04/11/2008 - 10:47
sorry but i cant understand what you mean? Can you please write what is the extended finction in callmanager? Thnx.
Jaime Valencia Fri, 04/11/2008 - 20:32
if you mean you want to have the callback feature for a call on the PSTN that's not just with you have
refer to this:
Q. Can I configure the Call Back Feature over PSTN?
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a0080191057.shtml#q15
if you do not meet those requirements then callback will work only for internal phones.
javalenc
if this helps, please rate
