VPN Endpoint w/ dynamic IP
Answered Question
Apr 7th, 2008
Hi!
I have a quick question. I like to set up an IPSec VPN which terminates on a c871. The C871 is hooked up to the internet but gets a new IP from the ISP every 24hours. Is it possible to run an Endpoint on the box if the WAN-IP changes frequently? Do I need a static IP?
Hope you can help.
Thanks...Andy
Correct Answer by srue about 9 years 3 weeks ago
if i understand correctly, you want to terminate remote access vpn's on the 871, which changes IP addresses every 24 hours?
if that's the case, you can do it, you just need to know the new address, or sign up for a dynamic DNS service, and connect using a DNS name.
Overall Rating: 5 (1 ratings)
Anonymous (not verified) Fri, 04/11/2008 - 10:42
Yes you can use dynamic ip on the router. It's not an issue.
Correct Answer
srue Fri, 04/11/2008 - 11:16
  • Blue, 1500 points or more
heinzel0302 Tue, 04/15/2008 - 23:48
Thats excactly what I liked to know. Thank you for this information.
