two cisco router with VPN
Apr 7th, 2008
I have two cisco router connected to each other by E1 connection ,also I implement a VPN between them (VPN over E1),one of these routers is connected also to the internet but when I tried to reach internet from the other router I could not>>I did a trace route from the router that is not connected to internet to real IP address but i could not reach(the default route on this router is toward the router connected to internet)
Any help??
rais Mon, 04/07/2008 - 05:23
  • Silver, 250 points or more
You may have to post your config.
The NAT statement [if required] on the Internet facing router should include the source space behind the other router.
The VPN is for the inter-site communication or for all traffic?
Thanks.
mohammady Mon, 04/07/2008 - 14:47
forget about nating..trace route to real IP from the router that is not connected to internet was not successful????what you suggest
Urfan Khaliq Wed, 04/09/2008 - 19:09
What does the traceroute show you, does the path try to go via the tunnel or via a default route?
