04-07-2008 05:38 AM - edited 03-18-2019 08:44 PM
I have a CUCM 6.0 integrated with an AD. Users are unable to change their PIN by themselves through ccmuser page. If I change it through the ccmadmin page manually, then users can modify PIN. Since I have 700 users I tried resetting PIN via BAT, but I received the attached error massage.
Lucas.
05-30-2008 07:04 AM
did anyone get this fixed, I am having the same problem?
05-30-2008 07:11 AM
nevermind just figured it out, I had to change the default policy to uncheck the user reset at next login option. Then re ran the BAT and the PIN worked.
05-30-2008 07:12 AM
oops wrong post, still having the problem described above...
