ACE 4710 load balancing configuration problem
Apr 7th, 2008
I configured ACE4710 as follow.
ACE4710-LAB/Admin#
interface gigabitEthernet 1/1
description Management Interface
switchport trunk allowed vlan 77
no shutdown
interface gigabitEthernet 1/2
description Server (Production) VLAN
switchport access vlan 5
no shutdown
interface gigabitEthernet 1/3
description Client VLAN
switchport access vlan 22
no shutdown
interface gigabitEthernet 1/4
shutdown
resource-class Nautilus
limit-resource all minimum 0.00 maximum unlimited
limit-resource sticky minimum 50.00 maximum equal-to-min
boot system image:c4710ace-mz.A1_7b.bin
hostname ACE4710-LAB
clock timezone standard EST
access-list ALL line 8 extended permit ip any any
probe tcp RDP
description Remote Desktop Health Check
port 3389
interval 5
faildetect 2
passdetect count 2
probe http Web-Services
description HTTP Health Check
interval 5
faildetect 2
passdetect count 2
request method get url /index.html
expect status 200 200
rserver host TSLAB1
description Terminal Server Lab 1
ip address 192.168.5.2
inservice
rserver host TSLAB2
description Terminal Server Lab 2
ip address 192.168.5.3
inservice
rserver host WSLAB1
description Web Server Lab 1
ip address 192.168.5.4
inservice
rserver host WSLAB2
description Web Server Lab 2
ip address 192.168.5.5
inservice
serverfarm host TSFARM1
description Terminal Servers
rserver TSLAB1 3389
inservice
rserver TSLAB2 3389
inservice
serverfarm host WSFARM1
description Web Servers
probe Web-Services
rserver WSLAB1 80
inservice
rserver WSLAB2 80
inservice
class-map match-all L4_TS_VIP_ADDRESS_CLASS
2 match virtual-address 192.168.22.26 tcp eq 3389
class-map match-all L4_VIP_ADDRESS_CLASS
2 match virtual-address 192.168.22.25 tcp eq www
class-map type management match-any remote_access
description Remote access traffic match
2 match protocol xml-https any
4 match protocol icmp any
5 match protocol telnet any
6 match protocol ssh any
7 match protocol http any
8 match protocol https any
9 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
class remote_access
permit
policy-map type loadbalance first-match L7_VIP_LB_ORDER_POLICY
class class-default
serverfarm WSFARM1
policy-map type loadbalance first-match L7_VIP_TSLB_ORDER_POLICY
class class-default
serverfarm TSFARM1
policy-map multi-match L4_LB_VIP_POLICY
class L4_VIP_ADDRESS_CLASS
loadbalance vip inservice
loadbalance policy L7_VIP_LB_ORDER_POLICY
policy-map multi-match L4_TSLB_VIP_POLICY
class L4_TS_VIP_ADDRESS_CLASS
loadbalance policy L7_VIP_TSLB_ORDER_POLICY
policy-map multi-match RDP-policies
loadbalance vip icmp-reply
policy-map multi-match SLB-policies
interface vlan 5
description Server-side Interface
ip address 192.168.5.88 255.255.255.0
no shutdown
interface vlan 22
description Client-side Interface
ip address 192.168.22.15 255.255.255.0
access-group input ALL
service-policy input L4_LB_VIP_POLICY
service-policy input L4_TSLB_VIP_POLICY
no shutdown
interface vlan 77
ip address 192.168.77.2 255.255.255.0
service-policy input remote_mgmt_allow_policy
no shutdown
ip route 0.0.0.0 0.0.0.0 192.168.22.1
context Nautilus
allocate-interface vlan 5
allocate-interface vlan 22
member Nautilus
From client VLAN (other than VLAN 22), I am unable to get to VIP address 192.168.22.25 and 192.168.22.26. These two VIP addresses are used to load balance two services. Can someone advise if I need to modify configuration on ACE 4710 to make this work. Thank you.
