PE to PE Connectivity
Answered Question
Apr 7th, 2008
Hi There,
What kind of physical connectivity between service provider VPN PE routers when it comes to providing MPLS IP VPN soultion to enterprise customers.
is it dedicated leased line among P and PE routers or GRE tunnel connectivity with Internet conenctivity.?
Thanks in advance.
Cheers,
Rajesh
Correct Answer by mohammedmahmoud about 9 years 2 months ago
Rajesh,
Yes, VPN Service providers' routers need not be connected to the internet to provide VPN services, the VPN service is provided over the service provider backbone with no referral to the internet unless internet access is required in addition to the VPN service.
BR,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
mohammedmahmoud Mon, 04/07/2008 - 07:31
  • Green, 3000 points or more
Hi Rajesh,
The SP routers (Ps and PEs) are connected either via direct links, or via PVCs over ATM backbone for example, all these interfaces must have label switching enabled, all these routers runs IGP, and the PE routers run MBGP with each other to exchange customer VPNv4 routes.
BR,
Mohammed Mahmoud.
rajeshk200_2 Mon, 04/07/2008 - 07:51
Mohammed,
Thanks for reply
It means P nad PE router nowhere exposed to internet conenctivity for providing IP VPN service.
Cheers,
Rajesh
Correct Answer
mohammedmahmoud Mon, 04/07/2008 - 12:47
Rajesh,
BR,
Mohammed Mahmoud.
