Inject default route(s) into EIGRP for Internet access
Apr 7th, 2008
I have a core 6500 sup II switch that is connected to 2 default gateway paths Metro and MPLS . 0.0.0.0 0.0.0.0 X.X.X.X is directly connected over Metro Ethernet. When that connection goes down I want the default gateway to adjust to network #2 0.0.0.0 0.0.0.0 H.H.H.H 10. what is the best practice for this? I put in a weight statement and pulled the default X.X.X.X connection but the H.H.H.H did not pick up.. Any thoughts on this?
noroutes4u Mon, 04/07/2008 - 07:52
Make sure the x.x.x.x is an ip address and not an interface. When you do a show ip route, do you see the floating static default route in your routing table? If you want to send this down stream, you need to redistribute this static route.
