Single Sign On for SSL Anyconnect and/or Smart Tunnel
Apr 7th, 2008
I wonder if anyone has created his or her own applet that combines using a custom application logon with the VPN SSL client (like SSO)that provides a single interface for the user. I realize that creating custom web portal is the easiest thing to do, but it requires two separate log on steps for the user - the VPN SSL authentication via user's web browser and the application's username and password prompt. The only real change is the GUI appearance to the end user. The Cisco SSL VPN Client (SVC), SSL Tunnel, and JavaScript remains the same.
Any information on API support for the Anyconnect client and/or clientless SSL Smart Tunnel to start an EXE automatically via JavaScript or ActiveX would be very helpful.
Scott
