ASA 5540 Context view
Answered Question
Apr 7th, 2008
I have a question on ASA on the GUI I have a choice to pick which Context I want to view. I have 2 one called mgmt and the other one admin. when I go on ssh into the asa all I can see is the admin context view how do I look at the config for the mgmt context view?
Correct Answer by JORGE RODRIGUEZ about 8 years 10 months ago
Warren,
To change to a different context from the admin context you simply have to changeto context follow by the context name mgmt which is your other context.
e.i
asa#changeto context
Go over this link which explains how to navigate between context through the command line.
See section Change Between Contexts and the System Execution Space
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808d2b63.shtml#changto
Rgds
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Mon, 04/07/2008 - 16:58
Warren,
e.i
Rgds
Jorge
wgranada1 Tue, 04/08/2008 - 05:04
Yes that is what I was looking for, thank you for that and the link as well. I guess I look things up the wrong way : )
JORGE RODRIGUEZ Tue, 04/08/2008 - 11:51
Warren, I am glad all have worked the link is very usefull, I also thank you also for the rating.
Bst Rgds
Jorge
