Netflow exporting
Apr 7th, 2008
I'm trying to configure Netflow on three different switches. I have noticed that I can specify to different netflow collectors in on of them (6500 sup 720) but no on the other two (6500 sup 2).
The command that I'm trying is
(config)#ip flow-export destination yyyy
I don't know if because the supervisor or the software version or why?
Jan Nejman Tue, 04/08/2008 - 01:27
what are you meaning under "different netflow collectors"? Do you mean more netflow export destinations (on each destination will be listening different collector/software) or different netflow ports (i.e for the first one port 9000, for the second one 9001) or different "templates" that will be sent (i.e. for the first collector src_IP,dst_IP and for the second one src_AS,dst_AS)?
Kind regards,
Jan Nejman
Caligare, Co.
Luis Melendrez Tue, 04/08/2008 - 07:23
I would like to specify different netflow export destinations.
ip flow-export destination 192.www.ww.w zzzz
