Paolo Bevilacqua Mon, 04/07/2008 - 10:36
  • Hall of Fame,
    Founding Member
First is data only module (no voice support), now also available as hwic-2ce1t1-pri.
Second is voice and data, with some limitations for data usage. Note the G703 version is not necessary unless you have unframed E1 circuits and are not willing to sacrifice 1 timeslot worth of bandwidth on them.
Tobivan_Helden_2 Thu, 04/10/2008 - 22:05
Paolo,
When you are saying, that HWIC-2CE1T1-PRI does not support voice, do you mean
that we are able to create _channel-group_ only if it is said in configuration terms ?
Are we able to create cas-group or pri-group ?
As for second one, can you, please, explain in a bit detail what is the limitation
you mentioned for G703 in data usage ?
Thank you.
Paolo Bevilacqua Fri, 04/11/2008 - 01:48
  • Hall of Fame,
    Founding Member
I mean that you cannot use the card for a voice gateway.
The vwic comes in two version, g703 and normal. The first one that is more expensive, is needed only when you have unframed E1 circuits, and is not necessary for PRI.
