H-REAP LAP won't register with Controller...
Apr 7th, 2008
I have a total of 27 LAPs on my wireless network from 17 different remote locations. All are AIR-LAP1242G-A-K9, 25 are in H-REAP mode and 2 are in LOCAL mode. I never have any issues with the LOCAL mode LAPs, they never DEREGISTER from the Controller even if connectivity to the Controller is lost, it will automatically Discover the Controller and RE register. The H-REAP mode LAPs however will DEREGISTER when connectivity is lost and will try to RE register but will fail. Debug shows failure is due to... Max retransmissions reached on AP... followed by... apfSpamProcessStateChangeInSpamContext: Down LWAPP event for AP . But when I change the mode to LOCAL, it registers successfully. Why is that and what is the fix for it?
truck_nguyen Mon, 04/07/2008 - 11:41
1 of 2
Here is the debug for the H-REAP mode LAP that fails...
Mon Apr 7 12:54:30 2008: 00:1f:6d:b8:52:e0 Received LWAPP DISCOVERY REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:20 on port '1'
Mon Apr 7 12:54:30 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Discovery Response to AP 00:1f:6d:b8:52:e0 on port 1
Mon Apr 7 12:54:40 2008: 00:1f:6d:b8:52:e0 Received LWAPP DISCOVERY REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:20 on port '1'
Mon Apr 7 12:54:40 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Discovery Response to AP 00:1f:6d:b8:52:e0 on port 1
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 Received LWAPP JOIN REQUEST from AP 00:1f:6d:b8:52:e0 to 06:0a:10:10:00:00 on port '1'
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 AP Kirby-WAP2: txNonce 00:1E:4A:FE:E2:20 rxNonce 00:1F:6D:B8:52:E0
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 LWAPP Join Request MTU path from AP 00:1f:6d:b8:52:e0 is 1500, remote debug mode is 0
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 Successfully added NPU Entry for AP 00:1f:6d:b8:52:e0 (index 9)
Switch IP: 10.20.30.5, Switch Port: 12223, intIfNum 1, vlanId 30
AP IP: 10.20.101.81, AP Port: 59280, next hop MAC: 00:0f:8f:7b:83:80
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Join Reply to AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 spam_lrad.c:1791 - Operation State 0 ===> 4
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 Register LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 12:54:50 2008: WARP IEs: (12)
Mon Apr 7 12:54:50 2008: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
Mon Apr 7 12:54:50 2008: Creating dot1x interface with key 00:1f:6d:b8:52:e0 - 0
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 Resetting the group key timer for 3724 seconds on AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 Register LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 12:54:50 2008: Creating dot1x interface with key 00:1f:6d:b8:52:e0 - 1
Mon Apr 7 12:54:50 2008: 00:1f:6d:b8:52:e0 Resetting the group key timer for 3636 seconds on AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:23
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Ignoring unsupported vendor-specific message 0x00409600-0003 from AP 00:1F:6D:B8:52:E0
Mon Apr 7 12:54:51 2008: spamVerifyRegDomainSlot: AP 00:1f:6d:b8:52:e0(slot 1) unsupported radio type 0XFF.
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 ADD_LOCAL_WLAN_PAYLOAD profile name CafeNet2
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Updating IP info for AP 00:1f:6d:b8:52:e0 -- static 1, 10.20.101.81/255.255.255.128, gtw 10.20.101.111
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Updated IP Domain info for AP 00:1f:6d:b8:52:e0 -- set 0, Domain
truck_nguyen Mon, 04/07/2008 - 11:43
2 of 2...
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Updating IP NamServer info for AP 00:1f:6d:b8:52:e0 -- set 0, nameserver 0.0.0.0
Mon Apr 7 12:54:51 2008: Send AP Timesync of 1207572891 source MANUAL
Mon Apr 7 12:54:51 2008: spamEncodeDomainSecretPayload:Send domain secret cafenetT to AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Config Message to AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:51 2008: Running spamEncodeCreateVapPayload for profileName CafeNet2[vapID: 1] SSID 'CafeNet2'
Mon Apr 7 12:54:51 2008: Running spamEncodeCreateVapPayload for profileName CafeExpress-Wifi[vapID: 2] SSID 'CafeExpress-Wifi'
Mon Apr 7 12:54:51 2008: Running spamSendCreateVlanMapping for00:1f:6d:b8:52:e0
Mon Apr 7 12:54:51 2008: Running spamEncodeCreateVlanMapPayload for00:1f:6d:b8:52:e0
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 AP 00:1f:6d:b8:52:e0 Error in sending AAA Db BlackList Table
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 AP 00:1f:6d:b8:52:e0 associated. Last AP failure was due to Link Failure
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Received LWAPP CHANGE_STATE_EVENT from AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Change-State-Event Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Down LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Received LWAPP Down event for AP 00:1f:6d:b8:52:e0 slot 0!
Mon Apr 7 12:54:51 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE COMMAND RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 12:54:55 2008: spamVerifyRegDomainSlot: AP 00:1f:6d:b8:52:e0(slot 1) unsupported radio type 0XFF.
Mon Apr 7 12:54:57 2008: 00:1f:6d:b8:52:e0 Max retransmissions reached on AP 00:1f:6d:b8:52:e0 for (CONFIGURE_COMMAND
, 8)
Mon Apr 7 12:54:57 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 12:54:57 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Down LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 12:54:57 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 12:54:57 2008: 00:1f:6d:b8:52:e0 Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 12:54:57 2008: 00:1f:6d:b8:52:e0 Received LWAPP Down event for AP 00:1f:6d:b8:52:e0 slot 1!
Mon Apr 7 12:54:57 2008: 00:1f:6d:b8:52:e0 Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
1 of 7
Debug of LOCAL mode LAP that successfully registers...
Mon Apr 7 13:04:30 2008: 00:1f:6d:b8:52:e0 Received LWAPP DISCOVERY REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:20 on port '1'
Mon Apr 7 13:04:30 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Discovery Response to AP 00:1f:6d:b8:52:e0 on port 1
Mon Apr 7 13:04:40 2008: 00:1f:6d:b8:52:e0 Received LWAPP DISCOVERY REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:20 on port '1'
Mon Apr 7 13:04:40 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Discovery Response to AP 00:1f:6d:b8:52:e0 on port 1
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 Received LWAPP JOIN REQUEST from AP 00:1f:6d:b8:52:e0 to 06:0a:10:10:00:00 on port '1'
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 AP Kirby-WAP2: txNonce 00:1E:4A:FE:E2:20 rxNonce 00:1F:6D:B8:52:E0
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 LWAPP Join Request MTU path from AP 00:1f:6d:b8:52:e0 is 1500, remote debug mode is 0
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 Successfully added NPU Entry for AP 00:1f:6d:b8:52:e0 (index 9)
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Join Reply to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 spam_lrad.c:1791 - Operation State 0 ===> 4
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 Register LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 13:04:51 2008: WARP IEs: (12)
Mon Apr 7 13:04:51 2008: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
Mon Apr 7 13:04:51 2008: Creating dot1x interface with key 00:1f:6d:b8:52:e0 - 0
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 Resetting the group key timer for 3684 seconds on AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 Register LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 13:04:51 2008: Creating dot1x interface with key 00:1f:6d:b8:52:e0 - 1
Mon Apr 7 13:04:51 2008: 00:1f:6d:b8:52:e0 Resetting the group key timer for 3799 seconds on AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:23
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Ignoring unsupported vendor-specific message 0x00409600-0003 from AP 00:1F:6D:B8:52:E0
Mon Apr 7 13:04:52 2008: spamVerifyRegDomainSlot: AP 00:1f:6d:b8:52:e0(slot 1) unsupported radio type 0XFF.
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 ADD_LOCAL_WLAN_PAYLOAD profile name CafeNet2
truck_nguyen Mon, 04/07/2008 - 11:45
2 of 7...
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Updating IP info for AP 00:1f:6d:b8:52:e0 -- static 1, 10.20.101.81/255.255.255.128, gtw 10.20.101.111
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Updated IP Domain info for AP 00:1f:6d:b8:52:e0 -- set 0, Domain
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Updating IP NamServer info for AP 00:1f:6d:b8:52:e0 -- set 0, nameserver 0.0.0.0
Mon Apr 7 13:04:52 2008: Send AP Timesync of 1207573492 source MANUAL
Mon Apr 7 13:04:52 2008: spamEncodeDomainSecretPayload:Send domain secret cafenetT to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Config Message to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:52 2008: Running spamEncodeCreateVapPayload for profileName CafeNet2[vapID: 1] SSID 'CafeNet2'
Mon Apr 7 13:04:52 2008: Running spamEncodeCreateVapPayload for profileName CafeExpress-Wifi[vapID: 2] SSID 'CafeExpress-Wifi'
Mon Apr 7 13:04:52 2008: Running spamSendCreateVlanMapping for00:1f:6d:b8:52:e0
Mon Apr 7 13:04:52 2008: Running spamEncodeCreateVlanMapPayload for00:1f:6d:b8:52:e0
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 AP 00:1f:6d:b8:52:e0 Error in sending AAA Db BlackList Table
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 AP 00:1f:6d:b8:52:e0 associated. Last AP failure was due to Link Failure
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Received LWAPP CHANGE_STATE_EVENT from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Change-State-Event Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Down LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Received LWAPP Down event for AP 00:1f:6d:b8:52:e0 slot 0!
Mon Apr 7 13:04:52 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE COMMAND RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:53 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE COMMAND RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:53 2008: 00:1f:6d:b8:52:e0 Received LWAPP STATISTICS_INFO from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:53 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Statistics Info Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:53 2008: 00:1f:6d:b8:52:e0 Received LWAPP CHANGE_STATE_EVENT from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:53 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Change-State-Event Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:53 2008: 00:1f:6d:b8:52:e0 Received LWAPP Up event for AP 00:1f:6d:b8:52:e0 slot 0!
truck_nguyen Mon, 04/07/2008 - 11:46
3 of 7...
Mon Apr 7 13:04:53 2008: 00:1f:6d:b8:52:e0 Received LWAPP RRM_CONTROL_RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:54 2008: 00:1f:6d:b8:52:e0 Received LWAPP RRM_CONTROL_RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:54 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE COMMAND RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:54 2008: spamVerifyRegDomainSlot: AP 00:1f:6d:b8:52:e0(slot 1) unsupported radio type 0XFF.
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Received LWAPP Down event for AP 00:1f:6d:b8:52:e0 slot 0!
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Down LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Received LWAPP Down event for AP 00:1f:6d:b8:52:e0 slot 1!
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Down LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Received LWAPP Up event for AP 00:1f:6d:b8:52:e0 slot 0!
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE COMMAND RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Received LWAPP CHANGE_STATE_EVENT from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Change-State-Event Response to AP 00:1f:6d:b8:52:e0
truck_nguyen Mon, 04/07/2008 - 11:47
4 of 7...
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Received LWAPP RRM_CONTROL_RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Received LWAPP RESET_RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 13:04:59 2008: 00:1f:6d:b8:52:e0 Deregister LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 13:05:41 2008: Received SPAM_UPLOAD_ROGUE_TABLE_ENTRY
Mon Apr 7 13:06:26 2008: spamVerifyRegDomainSlot: AP 00:1e:4a:90:17:e0(slot 1) unsupported radio type 0XFF.
Mon Apr 7 13:06:26 2008: spamVerifyRegDomainSlot: AP 00:1e:4a:90:21:20(slot 1) unsupported radio type 0XFF.
Mon Apr 7 13:06:26 2008: spamVerifyRegDomainSlot: AP 00:1e:4a:90:22:30(slot 1) unsupported radio type 0XFF.
Mon Apr 7 13:06:26 2008: spamVerifyRegDomainSlot: AP 00:1e:4a:90:30:a0(slot 1) unsupported radio type 0XFF.
truck_nguyen Mon, 04/07/2008 - 11:49
5 of 7
Mon Apr 7 13:07:05 2008: 00:1f:6d:b8:52:e0 Received LWAPP DISCOVERY REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:20 on port '1'
Mon Apr 7 13:07:05 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Discovery Response to AP 00:1f:6d:b8:52:e0 on port 1
Mon Apr 7 13:07:15 2008: 00:1f:6d:b8:52:e0 Received LWAPP DISCOVERY REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:20 on port '1'
Mon Apr 7 13:07:15 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Discovery Response to AP 00:1f:6d:b8:52:e0 on port 1
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 Received LWAPP JOIN REQUEST from AP 00:1f:6d:b8:52:e0 to 06:0a:10:10:00:00 on port '1'
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 AP Kirby-WAP2: txNonce 00:1E:4A:FE:E2:20 rxNonce 00:1F:6D:B8:52:E0
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 LWAPP Join Request MTU path from AP 00:1f:6d:b8:52:e0 is 1500, remote debug mode is 0
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 Successfully added NPU Entry for AP 00:1f:6d:b8:52:e0 (index 9)
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Join Reply to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 spam_lrad.c:1791 - Operation State 0 ===> 4
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 Register LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 13:07:25 2008: WARP IEs: (12)
Mon Apr 7 13:07:25 2008: [0000] dd 0a 00 c0 b9 01 00 00 00 08 01 01
Mon Apr 7 13:07:25 2008: Creating dot1x interface with key 00:1f:6d:b8:52:e0 - 0
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 Resetting the group key timer for 3699 seconds on AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 Register LWAPP event for AP 00:1f:6d:b8:52:e0 slot 1
Mon Apr 7 13:07:25 2008: Creating dot1x interface with key 00:1f:6d:b8:52:e0 - 1
Mon Apr 7 13:07:25 2008: 00:1f:6d:b8:52:e0 Resetting the group key timer for 3830 seconds on AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE REQUEST from AP 00:1f:6d:b8:52:e0 to 00:1e:4a:fe:e2:23
Mon Apr 7 13:07:29 2008: spamVerifyRegDomainSlot: AP 00:1f:6d:b8:52:e0(slot 1) unsupported radio type 0XFF.
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 ADD_LOCAL_WLAN_PAYLOAD profile name CafeNet2
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Updating IP info for AP 00:1f:6d:b8:52:e0 -- static 1, 10.20.101.81/255.255.255.128, gtw 10.20.101.111
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Updated IP Domain info for AP 00:1f:6d:b8:52:e0 -- set 0, Domain
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Updating IP NamServer info for AP 00:1f:6d:b8:52:e0 -- set 0, nameserver 0.0.0.0
truck_nguyen Mon, 04/07/2008 - 11:50
6 of 7
Mon Apr 7 13:07:29 2008: Send AP Timesync of 1207573649 source MANUAL
Mon Apr 7 13:07:29 2008: spamEncodeDomainSecretPayload:Send domain secret cafenetT to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Config Message to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: Running spamEncodeCreateVapPayload for profileName CafeNet2[vapID: 1] SSID 'CafeNet2'
Mon Apr 7 13:07:29 2008: Running spamEncodeCreateVapPayload for profileName CafeExpress-Wifi[vapID: 2] SSID 'CafeExpress-Wifi'
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 AP 00:1f:6d:b8:52:e0 Error in sending AAA Db BlackList Table
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP CHANGE_STATE_EVENT from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Change-State-Event Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 apfSpamProcessStateChangeInSpamContext: Down LWAPP event for AP 00:1f:6d:b8:52:e0 slot 0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP Down event for AP 00:1f:6d:b8:52:e0 slot 0!
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP CONFIGURE COMMAND RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP STATISTICS_INFO from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Statistics Info Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP Up event for AP 00:1f:6d:b8:52:e0 slot 0!
Mon Apr 7 13:07:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP RRM_CONTROL_RES from AP 00:1f:6d:b8:52:e0
truck_nguyen Mon, 04/07/2008 - 11:52
7 of 7
Mon Apr 7 13:07:41 2008: Received SPAM_UPLOAD_ROGUE_TABLE_ENTRY
Mon Apr 7 13:07:49 2008: 00:1f:6d:b8:52:e0 Received LWAPP STATISTICS_INFO from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:49 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Statistics Info Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:56 2008: 00:1f:6d:b8:52:e0 Received LWAPP ECHO_REQUEST from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:07:56 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Echo-Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:08:22 2008: 00:1f:6d:b8:52:e0 Received LWAPP RRM_CONTROL_RES from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:08:26 2008: 00:1f:6d:b8:52:e0 Received LWAPP ECHO_REQUEST from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:08:26 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Echo-Response to AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:08:29 2008: 00:1f:6d:b8:52:e0 Received LWAPP RRM_DATA_REQ from AP 00:1f:6d:b8:52:e0
Mon Apr 7 13:08:29 2008: 00:1f:6d:b8:52:e0 Successful transmission of LWAPP Airewave-Director-Data Response to AP 00:1f:6d:b8:52:e0
- It looks as though when the MAX Transmissions is met, the LAP will fail to register. Is there a way to increase the MAX Transmissions value or increase its Transmissions time?
cbaser007 Wed, 05/07/2008 - 06:38
Did you ever get a resolution? I've run into a similar issue after upgrading from 4.1.185 to 4.2.112. Now my H-REAP AP's connect to WLC and disconnect after about 10 seconds. I had a few that managed to connect successfully and stay connected after 4 hours 45 minutes, but a reboot starts the bouncing all over again. AP's in local mode are fine.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
