kleschd Mon, 04/07/2008 - 12:31
It happens to multiple people but not at the same time
jbarcena Mon, 04/07/2008 - 12:12
What type of calls are cutt off? External calls to the PSTN only? or do you have the problem with both external and internal calls?
What type of Gateway are you using for your PSTN calls? MGCP or H.323?
What errors do you see in the Application log when this happens?
Any SR or ES installed?
kleschd Mon, 04/07/2008 - 12:30
It happens on pstn calls. The routers are configured H323. I'm just getting on this problem so I have not checked the event logs.
Any SR or ES ? Tgis happens to multiple people but not neccesarily at the same time
jbarcena Mon, 04/07/2008 - 12:41
Without more information seems to be that you are loosing connectivity between the CCM server and the H.323 GW and probably you do not have call preservation configured that is why the calls are getting cut off. I strongly recommend you to check first the Application log and then probably some CCM detailed traces can give you more information about your problem.
