CME to CME, missing CLI on SIP trunk
Answered Question
Apr 7th, 2008
I have two CME 4.0 boxes either end of a 2mb link. There is a SIP trunk configured between these units which works fine apart from some missing CLI info on the called party for the caller.
So if John Smith (x2002) calls Emily Bond (x3003), John will only see the xtn number for Emily, not her name. However Emily will see both name and number of who is calling her.
Any ideas greatly appreciated.
thanks
Jamie
Correct Answer by paolo bevilacqua about 9 years 2 months ago
Hi, that is "connected party name update". I would upgrade to IOS 12.4(11)XJ4 and it should be resolved.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 04/08/2008 - 03:38
  • Hall of Fame,
    Founding Member
jamie.rickards Fri, 04/11/2008 - 03:53
Hi Paolo
Your advice worked a treat, updating to CME 4.1 has resolved the problem.
Thank you very much for your help.
best regards
Jamie
