CallManager Upgrade: Any option to check media before you start?
Apr 7th, 2008
I am getting ready to upgrade my Callmanager Business Edition 6.0 to 6.0.1.2000-4 and then to 6.1a. I have downloaded and burned the media, but I was wondering if there was a way to verify that the media was good before I started? I don't want to get halfway through the upgrade and find out that I've burned a corrupt .iso.
I tried using the CLI, but all I can do from there is list the contents of the DVD.
thanks,
Chris
hanslepire Tue, 04/08/2008 - 07:57
Does not have a MD5 hash to check ?
With CCM 5.1, when you downloading the file and when you start the update, you can check the number...
I don't no if in CCM 6 is the same, but I could think.
PS : if you want to backup your CCM with an another software that Cisco, you can try with a live CD of any linux distribution and use the utility dd to make a entire image of your HDD. You can save this image on a USB storage. Be sure that you must destroy raid, backup and after recreate raid...
Bye
