L2VPN on 7600 with 10GE interfaces
william.caban
Level 5
Level 5
It is my understanding that SIP-200/400 or OSMs are required for L2VPN on 7600.
- Is there a way to run L2VPNs on a 7600 having only 10GEs and GEs interfaces? What options are there available for L2 VFIs at these speeds?
-W
attrgautam
Level 5
Level 5
My recommendation would be to use the new ES-20 Line cards for L2VPN. SIP-200 and SIP-400 or the OSM dont support 10G and have their own VPN restrictions. ES-20 gives the option of 20 X 1G interfaces or 2 X 10G interfaces per slot and should suit your requirement.
