Fw logs
Apr 7th, 2008
Hi all,
i have fw logs
302013: Built outbound TCP connection 190313 for outside:10.24.31.80/445 (10.24. 31.80/445) to inside:10.253.216.47/1647 (10.253.216.47/1647)
302013: Built outbound TCP connection 190314 for outside:10.24.31.80/88 (10.24.3 1.80/88) to inside:10.253.216.47/1649 (10.253.216.47/1649)
302014: Teardown TCP connection 190314 for outside:10.24.31.80/88 to inside:10.2 53.216.47/1649 duration 0:00:01 bytes 2562 TCP FINs
304006: URL Server 10.4.31.168 not responding
302015: Built outbound UDP connection 190315 for outside:10.24.28.11/53 (10.24.2 8.11/53) to inside:10.253.216.26/1121 (10.253.216.26/1121)
302016: Teardown UDP connection 190315 for outside:10.24.28.11/53 to inside:10.2 53.216.26/1121 duration 0:00:01 bytes 563
302013: Built outbound TCP connection 190316 for outside:10.25.2.38/15880 (10.25 .2.38/15880) to inside:10.253.216.26/3185 (10.253.216.26/3185)
302014: Teardown TCP connection 190316 for outside:10.25.2.38/15880 to inside:10 .253.216.26/3185 duration 0:00:01 bytes 1189 TCP Reset-I
302013: Built outbound TCP connection 190317 for outside:10.24.28.71/2967 (10.24 .28.71/2967) to inside:10.253.216.47/1655 (10.253.216.47/1655)
302014: Teardown TCP connection 190313 for outside:10.24.31.80/445 to inside:10. 253.216.47/1647 duration 0:00:10 bytes 6810 TCP FINs
302016: Teardown UDP connection 190311 for outside:10.24.28.11/137 to inside:10. 253.216.15/137 duration 0:02:04 bytes 174
Can someone explainme if this logs shows that ciruit was down
mahesh18 Mon, 04/07/2008 - 20:30
also log shows
Device ID: disabled
r outside:10.24.31.80/445 (10.24.31.80/445) to inside:10.253.216.15/4586 (10.253 .216.15/4586)
302016: Teardown UDP connection 190306 for outside:10.24.31.81/389 to inside:10. 253.216.26/3182 duration 0:02:01 bytes 354
it is 506 pix
