VOIP gatekeeper problem.
Apr 7th, 2008
I have a PRI card connected to a PBX. Am able to make outgoing calls from internal extensions but external calls are not being forwarded through the PRI card. The setup has been OK till last week.This is the config on the card:
interface Serial0/3/0:15
no ip address
isdn switch-type primary-net5
isdn not-end-to-end 64
isdn protocol-emulate network
isdn incoming-voice voice
isdn send-alerting
no cdp enable
This is one my dial peers:
dial-peer voice 3000 pots
destination-pattern 41....
progress_ind setup enable 3
direct-inward-dial
port 0/3/0:15
forward-digits 4
Overall Rating: 4 (1 ratings)
gogasca Mon, 04/07/2008 - 22:21
  • Green, 3000 points or more
check using the following
show isdn status
Place a call and do a
debug isdn q931
For the config you have we are only able to send 4 digits to other side
Let us know above outputs
khchiang Mon, 04/07/2008 - 22:46
Dear all,
Please add "isdn sending-complete" on ISDN interface, & add "incoming called-number ." on dial-peer.
thanks
KH
nickolaskimutai Mon, 04/07/2008 - 23:09
Find the output on the gatekeeper based on the above:
VOIP#show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/3/0:15 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
2 Active Layer 3 Call(s)
CCB:callid=219, sapi=0, ces=0, B-chan=21, calltype=VOICE
CCB:callid=21A, sapi=0, ces=0, B-chan=20, calltype=VOICE
Active dsl 0 CCBs = 2
The Free Channel Mask: 0xFFE77FFF
Number of L2 Discards = 0, L2 Session ID = 5
Total Allocated ISDN CCBs = 2
VOIP#
19:38:47: ISDN Se0/3/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x0, Called num 3318
19:38:47: ISDN Se0/3/0:15 Q931: TX -> SETUP pd = 8 callref = 0x060A
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Called Party Number i = 0x80, '3318'
Plan:Unknown, Type:Unknown
19:38:47: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x860A
Cause i = 0x81A9 - Temporary failure.
This is an example of a call made to this gatekeeper from one of the gateways to an extension at a remote site:
030R#csim start 413318
csim: called number = 413318, loop count = 1 ping count = 0
csim err csimDisconnected recvd DISC cid(12232)
csim: loop = 1, failed = 1
csim: call attempted = 1, setup failed = 1, tone failed = 0
Same problem persists.
nickolaskimutai Tue, 04/08/2008 - 00:23
The problem was resolved by resetting the card on the PABX,
CAll are going on well now,
Thanks for your advice though.
