Need protocol supported router, firewall
Apr 7th, 2008
Hi all,
I need a Router and a Firewall which supports Inter Control Communication Protocol and IEC 60870-5-104 DNP over TCP-IP.
I found a Network Design Presentation in the below CEC link however it does not specified the router model number that is being used in the presentation.
http://wwwin.cisco.com/pcgi-bin/search/intranet/search_redirect.cgi?query=IEC+60870-5-104&query_string=sitesearch_title%3Dthe%2520Intranet%26restrict%3Dintranet-new
Please suggest a router and firewall which can support Inter Control Communication Protocol and IEC 60870-5-104 DNP over TCP-IP.
Thanks in advance.
paolo bevilacqua Tue, 04/08/2008 - 02:49
  • Hall of Fame,
    Founding Member
Hi, beside the fact the URL you linked is Cisco internal only, consider that routers don't care what protocol is carried over IP so in that sense, any model will do.
