EIGRP nei bounce
Answered Question
Apr 7th, 2008
Hi all,
i ahve question here.
I got alert for Router down.it was back up after 7mins.i check the logs they were clean.no circuit no Nei bounce.when i did sh ip eigrp nei it shows nei is uptime from last 5 mins.During alert i was unable to ping the router and its gateway.
Any answers what hap actually happened
Correct Answer by ruwhite about 9 years 3 months ago
Under router eigrp: eigrp log-neighbor-changes, I'm pretty certain, is the command you want to use.
Russ
Overall Rating: 5 (2 ratings)
drnteam Tue, 04/08/2008 - 03:47
Was it a power failure? What is the router model? Which IOS? Is the link down or router failure?
Eldo
HSBC Bank
mahesh18 Tue, 04/08/2008 - 07:04
Hi thanks for reply
it was not power failure
Cisco IOS Software, C2600 Software (C2600-ADVIPSERVICESK9-M), Version 12.3(14)T5 , RELEASE SOFTWARE (fc2)
it was no link down or router failure
ruwhite Tue, 04/08/2008 - 09:44
  • Gold, 750 points or more
Without any log messages, it's all going to just be a guess... :-( I would start by turning on eigrp log-neighbor-changes, and then you should get some notification of what is happening when a neighbor fails and comes back up.
Other than that, you can traipse through the EIGRP event log, and try to figure out which side actually went down, and possibly why, but that won't be an easy task, IMHO.
Russ
mahesh18 Tue, 04/08/2008 - 18:30
Hi thanks for reply,
what is exact syntax of that command
thnaks
Correct Answer
ruwhite Thu, 04/10/2008 - 09:47
Russ
