CAD - LRM not active
Answered Question
Apr 7th, 2008
Hi all.
After installing CAD (CCX 5.01 and CME)following error appears:
LRM non active, contact administrator.
Ideas?
Correct Answer by Riccardo Bua about 8 years 10 months ago
The error message is saying License Resource Manager is not starting, loaded or something went wrong with it install.
Check if you have any subsystem stopped with meaningful error messages or try reinstalling I would say just for the IPCCX side.
Riccardo
Overall Rating: 5 (1 ratings)
Correct Answer
Riccardo Bua Tue, 04/08/2008 - 00:04
Riccardo
arani Tue, 04/08/2008 - 22:12
Hi.
The reinstallation of IPCCX (repair) solved the problem.
Thank you a lot
f.gouger Mon, 06/02/2008 - 13:35
Hi guys
I have excatly the same error message and did the repair but with no success.
Do you have somethimg else in mind?
