mohammedmahmoud Tue, 04/08/2008 - 01:59
First you must make sure that you are using an IOS that supports SSH, please use the Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Here you are a simple example and please check the below document for more details:
username test password test
hostname Routerx
ip domain-name cisco.com
crypto key generate rsa
line vty 0 15
transport input ssh
login local
Configuring Secure Shell
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsec_c/part25/ch10/schssh.htm
BR,
Mohammed Mahmoud.
dsturgeon Tue, 04/22/2008 - 06:09
Is there a 'best practice' as related to running ssh instead of telnet on switches such as the 2950? I have put the crypto image on one of my switches to test but it obviously uses more memory.
Richard Burts Tue, 04/22/2008 - 07:42
David
In absolute terms SSH is more secure than Telnet and for most people that makes it better and for some it is perhaps a "best practice". But you are correct that it requires a crypto image and for many versions that does involve more memory.
So in your case which is more important: better security or minimizing memory requirements?
Rick
