env_vars file and LWAPP Migration
Apr 8th, 2008
Hello
I wonder if any one can help?
We are migrating over 360 WAP to LWAPP and have encountered an issue associated with the env_vars file.
It appears that the env-vars file is referenced during the LWAPP migration tool upgrade process and the env_vars file contains out of date IP information that results in the newly converted LWAPP device having an incorrect IP address of incorrect DNS address.
We have tried deleting the env_vars file without success, as a 'reload' as part of the migration process recreates the dodgy env_vars information.
Is there any way to find the location of the old IP information that is being used by the WAP to create the env_vars file? It is not the running config, as the IP info is years out of date, so it must be hidden somewhere in flash?
Is there a way to find out where and then delete it?
Does anyone else have a solution that does not involve me having to climb a ladder 360 times and physically remove the WAP, perform a local upgrade and then re-install it?
thank you for any advice
regards
Bryn
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
