2811 Router PBR : Two ISPs : Mail --> ISP1, Browsing --> ISP2
Apr 8th, 2008
Hi all,
We have a scenario where there is a 2811 router, connected to two ISPs ( ISP1 and ISP2). The requirement is that Email has to be forwarded through ISP1 and browsing should happen through ISP2. But if link to ISP1 fail then mail should go through ISP2 and when the link to ISP1 comes up back again mail should go through ISP1 again. Similarly for browsing.
Is this possible? Are there any configuration samples available?
Thanks and Regards
Sonu.
Overall Rating: 3 (1 ratings)
royalblues Tue, 04/08/2008 - 01:57
  • Green, 3000 points or more
For multihoming you should have your own public address space. If you do not own the address space it is more likely that ISP 1 would drop the packets for ISP2 subnets and vice versa
If you own the address space, you can force the mail traffic on the outbound direction but we cannot guarantee the inbound direction of the traffic
eg config
interface Ethernet0/1
Description inside
ip address 10.10.10.1 255.255.255.0
ip policy route-map mail
interface serial 0/1
description " ISP1 link "
ip address 20.20.20.1 255.255.255.252
interface serial 0/2
ip address 30.30.30.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 30.30.30.2
ip route 0.0.0.0 0.0.0.0 20.20.20.1 20
route-map mail permit 10
match ip address 1
set ip next-hop 20.20.20.2
access-list 1 permit host
Narayan
