Tracking ethernet interface?
Apr 8th, 2008
Very basic issue, but ...
Suppose there are two b2b connections b/w routers on ethernet. One should be primary & other one secondary.
One way to do this is through tunnel.
Second way through tracking (reliable static routing)
Any other way? (third way)
Thanks in advance.
Overall Rating: 3 (1 ratings)
guruprasadr Tue, 04/08/2008 - 02:44
  • Gold, 750 points or more
HI Bandhani, [Pls Rate if HELPS]
I recently heard from an NetPro Expert about this feature in Ethernet for Biredection fast detection of failures.
Please find the attachment having more information on the CISCO Document.
Pls Rate if HELPS.
Best Regards,
Guru Prasad R
