Caclculate VoIP metrics using SAA/rttMon
Apr 8th, 2008
Please can somebody help me with calculating the VoIP parameters jitter,delay,packet loss using rttMon MIB.It gives lots of OID's .But I am not clear enough to pick up which one.
Thanks in advance for the help
andrew.butterworth Tue, 04/08/2008 - 02:59
  • Gold, 750 points or more
Hi, I downloaded a sample MRTG script ages ago and tested it on some Catalyst 3550's & 3560's using ip sla (saa). The OID's in the script were:
jitter .1.3.6.1.4.1.9.9.42.1.5.2.1.7.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.17.1
RTT .1.3.6.1.4.1.9.9.42.1.5.2.1.2.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.2.1 & .1.3.6.1.4.1.9.9.42.1.5.2.1.1.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.1.1
Packet loss .1.3.6.1.4.1.9.9.42.1.5.2.1.26.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.27.1
I apologise for my lack of SNMP knowledge in advance....
Andy
freebird123 Tue, 04/08/2008 - 03:38
Thanks for the information.Actually I am also new to this field of Network Management.I am drilling through the OIDs but not getting exactly what to pick up...I am picking up the oids from the rttMonLatestJitter table.
I tried the oids you mentioned.Only the thing is the end .1 which u specified for evry oid it shows no mib information when i query.help me on that to understand
Thanks for the help
andrew.butterworth Tue, 04/08/2008 - 03:44
Hi, as I said apologies for my lack of SNMP knowledge. I can post the MRTG script I used however there isn't much more in it apart from the values to graph:
# SAA POS JITTER
Target[test-saa-posjitter]: .1.3.6.1.4.1.9.9.42.1.5.2.1.7.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.17.1:[email protected]
Maxbytes[test-saa-posjitter]: 10000
Title[test-saa-posjitter]: SAA MAX Positive jitter
PageTop[test-saa-posjitter]:
ShortLegend[test-saa-posjitter]: ms
YLegend[test-saa-posjitter]: miliseconds
Legend1[test-saa-posjitter]: MAX Positive jitter SD
Legend2[test-saa-posjitter]: MAX Positive jitter DS
LegendI[test-saa-posjitter]: SD:
LegendO[test-saa-posjitter]: DS:
Options[test-saa-posjitter]: growright, gauge, nopercent
# SAA NEG JITTER
Target[test-saa-negjitter]: .1.3.6.1.4.1.9.9.42.1.5.2.1.7.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.17.1:[email protected]
Maxbytes[test-saa-negjitter]: 10000
Title[test-saa-negjitter]: SAA MAX Negative jitter
PageTop[test-saa-negjitter]:
ShortLegend[test-saa-negjitter]: ms
YLegend[test-saa-negjitter]: miliseconds
Legend1[test-saa-negjitter]: MAX Negative jitter SD
Legend2[test-saa-negjitter]: MAX Negative jitter DS
LegendI[test-saa-negjitter]: SD:
LegendO[test-saa-negjitter]: DS:
Options[test-saa-negjitter]: growright, gauge, nopercent
# SAA RTT
Target[test-saa-rtt]: .1.3.6.1.4.1.9.9.42.1.5.2.1.2.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.2.1:[email protected] / .1.3.6.1.4.1.9.9.42.1.5.2.1.1.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.1.1:[email protected]
Maxbytes[test-saa-rtt]: 10000
Title[test-saa-rtt]: SAA RTT
PageTop[test-saa-rtt]:
SAA RTT
ShortLegend[test-saa-rtt]: ms
YLegend[test-saa-rtt]: miliseconds
Legend1[test-saa-rtt]: Latest RTT
Legend2[test-saa-rtt]: Latest RTT
LegendI[test-saa-rtt]: RTT:
LegendO[test-saa-rtt]: RTT:
Options[test-saa-rtt]: growright, gauge, nopercent
# SAA Packet loss
Target[test-saa-pktloss]: .1.3.6.1.4.1.9.9.42.1.5.2.1.26.1&.1.3.6.1.4.1.9.9.42.1.5.2.1.27.1:[email protected]
Maxbytes[test-saa-pktloss]: 10000
Title[test-saa-pktloss]: SAA Packet loss
PageTop[test-saa-pktloss]:
SAA Packet loss
ShortLegend[test-saa-pktloss]: pkts
YLegend[test-saa-pktloss]: Packets
Legend1[test-saa-pktloss]: Packet loss SD
Legend2[test-saa-pktloss]: Packet loss DS
LegendI[test-saa-pktloss]: SD:
LegendO[test-saa-pktloss]: DS:
Options[test-saa-pktloss]: growright, gauge
Hopefully someone with more a bit more of a clue than me will reply....
Andy
freebird123 Tue, 04/08/2008 - 03:48
Thanks Sir,
That will help me to understand.I will get back to you if I find any difficulty.
Thanks again for help,
Shivani
