CSM Load Balancer Help
Hey all,
I had a config working for load balancing websites but now need something to work for a flash app that uses port 1935 instead.
Everything worked but I couldn't see the real source IP (which is a requirement of the business). I know that this was because I was taking it from the HTTP header before and it's not HTTP now.
What are my options here? Is there something similar I could do or do I need to change the basic design?
My design at present looks like this:
Client -- CSM -- FWSM -- Real Servers
The servers have a DG of the FWSM and are on VLAN205.
module ContentSwitchingModule 12
vlan 205 server
ip address 10.1.205.5 255.255.255.0
vlan 150 client
natpool MAND8 10.1.205.50 10.1.205.50 netmask 255.255.255.0
probe TCP_80 tcp
interval 5
failed 3
port 80
map SOURCEIPHEADER header
insert protocol http header sourceip header-value %is
serverfarm MAND8
nat server
nat client MAND8
failaction reassign
real 10.1.205.209
no inservice
real 10.1.205.219
inservice
probe TCP_80
policy INSERTSOURCEIP
header-map SOURCEIPHEADER
serverfarm MAND8
vserver MAND8
virtual 10.1.205.50 tcp 1935
vlan 205
unidirectional
serverfarm MAND8
advertise active
persistent rebalance
inservice
As I say, the above config works fine, apart from the NAT so if anyone has any ideas that would be great!
Thanks in advance
Anthony
Gilles Dufour Tue, 04/08/2008 - 03:15
  • Cisco Employee,
You need to change the design.
Do something like this
client -- FW -- CSM --- servers
Have the same configured in bridge mode so the servers can keep the FW as their DG.
After that you can remove the natpool from the serverfarm and you will see the client ip address on the servers.
Gilles.
Ok, thanks Gilles...
I'm trying to do what you suggest but what's the main config difference between what I have and what you suggest?
I have the outside FW VLAN as VLAN15 - VLAN205 is one that is off the FWSM and VLAN150 is just on the CSM.
So how do I change what I have to 'bridge'?
Thanks for the help
Anthony
Gilles Dufour Tue, 04/08/2008 - 03:29
  • Cisco Employee,
The goal is to have the traffic hit the CSM before it goes to the firewall which could send the traffic back to the client without going through the CSM.
If I understand correctly, the servers are in vlan 205.
So you need sth like this :
vlan15 -- FW ---- vlan150 ---- CSM ----vlan205
Configure the same ip in vlan150 and vlan205 for the CSM.
Use an ip from the servers subnet.
Remove vlan 205 from the FW and replace it with vlan 150.
I hope this makes sense like this.
Don't hesitate to send more questions if you need to clarify something.
Gilles.
Gilles Dufour Tue, 04/08/2008 - 07:11
  • Cisco Employee,
the CSM will bridge between the FW and the servers.
But the FWSM can't have direct access to the server vlan.
So you keep everything the same on the firewall, but you need to remove the server vlan and replace it with a new vlan id that will exist only between the csm and the fwsm.
The fwsm will keep the same ip addresses.
Just the vlan id will change.
The csm takes care of the rest.
Gilles.
Ok, I think I understand. I've deleted VLAN205 on the FWSM and replaced it with VLAN150 but with the original VLAN205 IP address - to still be used as the DG.
When I try now I can see requests coming into the server from the non-natted address but the page doesn't load.
Should I have a gateway configured on either the server/client VLAN's on the CSM config to sort this problem or is it something else?
Thanks again!
Hey Gilles,
Thanks for all your help!
I got it working in the end. I kept 205 as the bridged VLAN so that my other servers can stay on that without needing to be changed, then created a new VLAN for the servers that are to be load balanced. I now see the source IP and all is good!
Next problem!!
Do you know if it's possible for a probe script to look inside a text file and look for a certain line of text or if not look for a certain line of text on a webpage i.e. 'ok' or whatever?
I'm reading loads of stuff at the moment but you seem to have the answers so thought I'd ask!!
Cheers,
Anthony
