Help with access list (pasted below)
Apr 8th, 2008
Can someone explain part of this access list I'm not sure if I need it. The access list is called "inbound_acl"
And I need to know what the below achieves:
permit tcp 80.71.156.64 0.0.0.31 any eq telnet
permit tcp 80.71.156.64 0.0.0.31 any eq 22
permit tcp 80.71.156.64 0.0.0.31 any eq ftp-data
permit tcp 80.71.156.64 0.0.0.31 any eq www
permit tcp 80.71.156.64 0.0.0.31 any eq 443
80.71.156.64 and upwards is our external IP range (firewall etc)
Access List:
ip access-list extended inbound_acl
permit udp any any eq isakmp
permit esp any any
deny icmp any any timestamp-request
deny icmp any any timestamp-reply
permit icmp any any
permit udp any any eq ntp
permit ip 192.168.20.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.21.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.30.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.40.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.50.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.60.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.70.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.80.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.90.0 0.0.0.255 172.19.8.0 0.0.0.255
permit ip 192.168.100.0 0.0.0.255 172.19.8.0 0.0.0.255
interface Dialer1
ip address negotiated
ip access-group inbound_acl in
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ****
ppp chap password 0 ****
ppp pap sent-username **** password 0 ****
crypto map CSO_Crypto_Map
Richard Burts Tue, 04/08/2008 - 04:01
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Andy
The part of your question about what that section of access list does is fairly simple to answer but the part about whether you need it requires understanding of your environment that you have not provided. What the access list does is to provide a specific subnet (which you identify as your external IP range) with access to any destination address for Telnet, SSH, FTP, and web (both HTTP and HTTPS).
You show the access list being assigned inbound on the dialer interface. But we do not know what device this is on and we do not know whether your external IP range is really outside on your dialer interface. So we do not know whether you need this part of the access list on this interface. I also find it a bit odd that this access list permits 4 specific TCP protocols but no other IP access (no DNS, no ICMP or UDP) so the access list provides only very limited functionality for your external IP range. Perhaps that is what was intended - or perhaps not - we just do not know.
Rick
