Gw 2821 & Unavailable Controllers E1
Guys,
I wonder, what can be the cause the router
- does not show controller 0/1/0 & 0/1/1 in running-config
- consequently it does not allow to 'conf t | controller e1 0/1/0'
What can be the problem ? Thanks.
{ *** Related Information ***
#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(9)T, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
R1 uptime is 16 minutes
System restarted at 10:59:42 UTC Tue Apr 8 2008
System image file is "flash:c2800nm-advipservicesk9-mz.124-9.T.bin"
Cisco 2821 (revision 53.50) with 247808K/14336K bytes of memory.
Processor board ID FCZ1014700H
2 Gigabit Ethernet interfaces
2 Low-speed serial(sync/async) interfaces
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
#sh diag
Slot 0:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
Onboard VPN : v2.2.0
EEPROM contents at hardware discovery:
PCB Serial Number : FOC101117EG
Hardware Revision : 1.0
Top Assy. Part Number : 800-26921-01
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20060316
Chassis Serial Number : FCZ1014700H
Chassis MAC Address : 0017.5a66.9790
MAC Address block size : 32
CLEI Code : CNMJ6P0BRB
Product (FRU) Number : CISCO2821
Part Number : 73-8853-03
Version Identifier : V02
EEPROM format version 4
PVDM Slot 0:
32-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 3.2
Part Number : 73-8539-04
Board Revision : A0
Fab Version : 03
PCB Serial Number : FOC10103G0J
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-32
Version Identifier : NA
WIC Slot 1:
VWIC2-2MFT-G703 - 2-Port RJ-48 Multiflex Trunk - T1/E1 & G.703
Hardware Revision : 0.0
Top Assy. Part Number : 800-24920-04
Board Revision : C0
Fab Version : 04
PCB Serial Number : FOC10140L6F
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-G703
Version Identifier : V01
#sh controllers e1
paolo bevilacqua
Please configure:
card type e1 1
And the controllers will appear.
Note your IOS is not updated an can present many bugs.
paolo bevilacqua
Please configure:
card type e1 1
Thanks, Paolo. Bull's-eye advice.
Conf mode 'card type e1 0 1' reveal interfaces.
It happens to everyone that configure a vwic2 the very first time.
Thanks for the nice rating and good luck!
