Native VLAN ????
Answered Question
I am desperately looking for Information on Native VLAN. But what i have read on net i am not clear.
So far what i understood, is Native VLAN packets are not tagged. For Eg, if you have VoIP, then IP-Phone and switch port will have Voice packets tagged as Voice VLAN, but the data from your PC will not get tagged due to Native vlan BECAUSE IP PHONE CANNOT HANDLE TAGGING FOR DATA...Am i Correct ???..
Also why would you need Management VLAN as Native in Layer-2 switch or Layer-3 switch...Any information will be very much appreciated. I am so confuse.
Best Regards,
Hassan..
Correct Answer by Istvan_Rabai about 8 years 9 months ago
Hi Hassan,
As an addition to Edison's post.
It seems to me that you are confused on the "native vlan" term.
It has 2 meanings:
1. On traditional 802.1q trunks it is the vlan that is untagged.
Example:
interface fastethernet 1/0
switchport
switchport trunk native vlan 2
switchport mode trunk
In this case vlan 2 is the native vlan of the 802.1q trunk, and it is untagged.
2. On access ports with voice vlans: the native vlan is the vlan where the port is configured with the "switchport access vlan x" command.
Example:
switchport
switchport mode access
switchport voice vlan 5
switchport access vlan 3
In this case the voice vlan is vlan 5 (tagged).
The native vlan is vlan 3 (this is also untagged).
Cheers:
Istvan
Correct Answer by Edison Ortiz about 8 years 9 months ago
When a VoIP phone boots up, it actually comes up in the native Vlan, once it gets its information from DHCP, it switches to the designated voice vlan.
Standard NICs for PCs do not have this intelligent built into the hardware so that's the reason you use 'native' Vlans for PCs. However, there are NICs that support trunking so you can actually configure trunking between a switch and an end station.
As for using the 'Management' Vlan as 'native, that's just Best Practice in case the switch loses its trunk status and you still are able to connect by using its 'native' Vlan and manage it.
HTH,
__
Edison.
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Tue, 04/08/2008 - 06:42
HTH,
__
Edison.
Correct Answer
Istvan_Rabai Tue, 04/08/2008 - 08:29
Hi Hassan,
It has 2 meanings:
Example:
switchport
Example:
switchport
Cheers:
Istvan
