Recommendation for WAN router
Apr 8th, 2008
I'm looking for a recommendation on the best (cheapest) router for connecting 2 offices via a LAN extension link (10mbps). Obviously the router will need 2x 10Mbps ethernet ports and also needs to support QoS. I was thinking of cisco 851s, but before I spend the money I was wondering if these are the best routers for the job.
Any thoughts much appreciated!
-A
Paolo Bevilacqua Tue, 04/08/2008 - 06:38
  • Hall of Fame,
    Founding Member
You can use an 871 or a 1801 for this.
The 851 does not support QoS as well some other features that are useful for professional results.
