Determine Max Simultaneous Calls on 3825
Apr 8th, 2008
Is there a way/command to determine (from the router)the maximum number of smultaneous calls that have run through a 3825 Voice Gateway? IOS is currently 12.4(19). Thanks in advance.
Paolo Bevilacqua Tue, 04/08/2008 - 06:33
Do you have CM ? If so, it can produce many statistics of this type.
Else, you can monitor the ISDN MIB with any snmp tools and it will produce a graph of channel usage over time.
nagel Tue, 04/08/2008 - 06:36
We have CM but I would rather determine from the router side as I am on Network Side of house and I don't want to interfere with phone guys. The ISDN MIB might work for me - do you have any additional info on it?
nagel Tue, 04/08/2008 - 06:46
It doesn't appear that ISDN MIB RFC 2127 is available for the 3825 platform. Do you know for a fact that it is. It all appears that it is only available for BRI connect. We currently utilize PRI.
