Historical Reports-Login Time is behind an hour
Apr 8th, 2008
When running reports for the login times for the agents, the hours are off. It seems that it has reverted back to before Daylight Savings Time. It is one hour behind. When I go into the Agent Reports the time is off by an hour. Thanks.
Jonathan Schulenberg Wed, 04/09/2008 - 10:33
  • Cisco Designated VIP,
    2017 IP Telephony
Hi Henry-
Your post is missing any detail that might assist people in helping you. Could you please post what product, version and patch level, and other relevant data?
-Regards,
Jon
Henry.Ola Thu, 04/10/2008 - 07:26
Hello Jon,
The version is:
IPCC 4.0(4)
2000.4.5bSR8OS
OS Image 2000.4.3a
The time on the server is correct and the daylight saving time is unchecked, so I have no clue why when running reports it's an hour behind.
Thanks Henry
