04-08-2008 06:52 AM - edited 03-05-2019 10:15 PM
My fa0/0 is getting a public ip address from my isp via dhcp set on the interface 63.17.X.X
and
my fa0/1 is 192.168.0.1 /24
Since both are connected interfaces do I have to do a ip route command to get out on the internet? If so, I do not know the next hop of the ISP. For example:
ip route 63.17.0.0 - subnet mask - next hop???
Am I going about this wrong?
Solved! Go to Solution.
04-08-2008 07:18 AM
you will also have to setup PAT or NAT if you want to get internet.
04-08-2008 07:05 AM
Your default route should be
ip route 0.0.0.0 0.0.0.0 dhcp
or
ip route 0.0.0.0 0.0.0.0 fastethernet0/0
HTH,
__
Edison.
04-08-2008 07:18 AM
