ACE - Error: resources in use (2)
Answered Question
Apr 8th, 2008
The heading marked (2) as I found a similar question before.
When trying to add resource to another context, error occures.
details:
resource-class 001_Res
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 30.00 maximum equal-to-min
resource-class 002_Res
  limit-resource all minimum 10.00 maximum unlimited
ACE/Admin(config-context)# member 002_Res
The problem is when trying to add a resource-class to a new Context on the ACE,, Error message appears saying that "resource in use"?
Could you help please
Correct Answer by Gilles Dufour about 9 years 2 weeks ago
Never, never, never do a max unlimited for syslog.
Because the syslog file keeps increasing until it consumes all the resources so you can't allow new context to receive some resources for the syslog.
So, clear the logging buffer and then adjust the syslog resource and limit the max.
Gilles.
Overall Rating: 4 (2 ratings)
Correct Answer
Gilles Dufour Tue, 04/08/2008 - 08:11
  • Cisco Employee,
Gilles.
deephazz02 Wed, 06/11/2008 - 12:21
Hello Gilles,
by adjust the syslog resource, dou you mean
"limit-resource buffer syslog minimum nn maximum equal-to-min" ?
Thibault.
Gilles Dufour Wed, 06/11/2008 - 15:18
  • Cisco Employee,
Thibault.
Correct. Make the syslog resource max equal-to-min.
Gilles.
deephazz02 Wed, 06/18/2008 - 08:21
Gilles,
Thank you for your reply.
just a quick question, does the memory re-allocation has any impact on the =existing contexts when change are made to the memory allocation in resource classes?
I mean I have to reduce the allcoated memory for most of the contexts on a content switch I i just wondering if it will bring anything down while change the allocated-memory values.
Regards.
Thibault.
