Switches for BCMSN Exam
Apr 8th, 2008
Hi All,
Just wondering what you could recommend for switches for the BCMSN exam? I've looked at the cisco suggested lab, but I was hoping to find the 'lowest cost' switches possible, that would cover most of what I need to learn...
Barring that any suggested rack rentals for this endavour?
BWG
Istvan_Rabai Tue, 04/08/2008 - 09:32
Hi Brad,
The lowest cost switches that would be enough for the preparation for BCMSN exam may be the following, in my opinion:
Catalyst 3560-8PC:
8 Ethernet 10/100 ports with PoE and 1 dual purpose 10/100/1000 and small form-factor pluggable (SFP) port; compact form-factor with no fan
2960-8TC-L:
8 Ethernet 10/100 ports and 1 dual-purpose uplink
Cheers.
Istvan
srue Tue, 04/08/2008 - 09:50
you can probably find a 24 port 3550 on ebay for much cheaper than you will find the 8 port 3560's. Those would be just as good.
jrensink78 Tue, 04/08/2008 - 12:50
You would probably want to procure a full switch block. Getting 2- 3550 switches with the EMI image should be good for your layer 3 switches. A couple of 2950s would probably work well for your access level switches.
