CVP and IPCC Backups
rbua Tue, 04/08/2008 - 23:47
Hi Charl,
I guess we are talking about disaster recovery scenarios here.
I always recommend at least the following:
1) ICM/IPCC server registries backup/export
2) ICM Config export via ICMDBA export from the logger
3) ICM/IPCC Logger/HDS Incremental backup daily and a complete backup weekly scheduled
4) Webview DB backup weekly
5) Custom webview templates export/copy
6) CVP OAMP DB Backup, frequency would depend on the frequency of config changes
Riccardo
joesnyde Tue, 02/24/2009 - 08:17
From SQL Enterprise Manager you should expand the Database tree and see wvdb (Webview Database).
Joe
webstd.design Wed, 02/25/2009 - 23:50
ICM_SideA have two database connection:
local with databases:
customer_baA
customer_sideA
wvdb
and
ICM_SideA\CADSQL with databases:
craDistribution
FCRasSvr
wvdb
What databases should I backup in ICMSideA\CADSQL connection?
Should I backup customer_sideA in local connection database?
Anonymous (not verified) Tue, 04/08/2008 - 23:53
If you are running these systems on Mirrored Hard disks, the fastest and yet raliable option would be to mirror one set of disks and keep them out. I used this option and worked well.
Sukhesh
webstd.design Thu, 02/26/2009 - 23:10
But you mean only hardware failure or also software? Forexample if I have some problem with booting server because there is software problem?
