IVR scripts aef files backup
jsheppard
I'm about to start work on a spanish IVR. I'm going to use alot of my existing scripts, and I want to save alot of them for the spanish IVR. Is there anyway to save multiple scripts at the same time. I don't want to open every script I need and click file>save as. Any ideas?
chris_b
The way we do it is to create a BARs backup of the IVR and then extract the .aef files using winzip. Down side is that you have to load them manually.
Cheers
Chris
Thanks Chris!
