MCS Server Serial Number via SSH
Apr 8th, 2008
Hi! Can I get the serial number of an HP MCS server running CM 5.1 through the SSH session? I tried all the show commands and can't find it anywhere.
toddcarp123 Tue, 04/08/2008 - 09:20
Here's my "show hardware" output:
admin:show hardware
HW Platform : 7845H2
Processors : 2
Type : Intel(R) Xeon(R) CPU 5140 @ 2.33GHz
CPU Speed : 2333
Memory : 4096 MBytes
Object ID : 1.3.6.1.4.1.9.1.586
OS Version : UCOS 2.0.1.0-71
RAID Details :
Smart Array P400 in Slot 1
Logical Drive: 1
Fault Tolerance: 1+0
Heads: 255
Sectors Per Track: 32
Cylinders: 17562
Stripe Size: 64 KB
Status: Ok
Array Accelerator: Enabled
Has Data On Drive: True
Unique Identifier: 600508B10010443953554B4452500004
Preferred Controller Chassis Slot: 1
Logical Drive: 2
Heads: 255
Cylinders: 17562
Stripe Size: 64 KB
Status: Ok
Unique Identifier: 600508B10010443953554B4452500005
admin:
I don't see it anywhere...
tzunt Tue, 04/08/2008 - 19:20
I see what you mean. The documentation does say that command will show the serial #.
However, I am not able to see it via an SSH session w/ show hardware or even show tech all. [CUCM 5.1.3]
Is it a strict requirement to get the serial # thru SSH only?
I see my serial # in the web interface:
https://myhpmcsserver/iptplatform
then select Show>Harware
I also feel duty bound to warn you that this serial # is one of two that I see stamped on my HP MCS servers. Not sure what the other one is for..
Tony
Jaime Valencia Wed, 04/09/2008 - 06:13
no, actually most of the times i ask users to get me the SN if needed thru the webadmin and it's the same thing. usually it's easier to ask it that way.
javalenc
if this helps, please rate
