Scheduled Unity Restart Tool - CSA Agent?
Answered Question
Apr 8th, 2008
Does the CSA agent interfere with a reboot scheduled using the Scheduled Unity Restart Tool?
Correct Answer by Tray Stoutmeyer about 9 years 3 months ago
I just did a one now on a Unity 4.0(5) system with the latest CSA installed and CSA did not interfere. You should test yours before deploying it to make sure you have the same result.
Tray
Overall Rating: 5 (1 ratings)
Correct Answer
Tray Stoutmeyer Tue, 04/08/2008 - 10:52
  • Cisco Employee,
Tray
mlitka Tue, 04/08/2008 - 10:54
Tray -
Will do. Thanks for your feedback!
