Ring down question
Apr 8th, 2008
I have a ring down translation set up to a 1800 number for outbound calls. The user would like the PIN number for this destination entered as well when the call is made. Is there a setting or field in the translation so that the PIN can be entered?
-Shikamaru
Jaime Valencia Tue, 04/08/2008 - 10:30
CUCM? CME? version?
not sure what u mean by PIN, is this a FAC or CMC you want? if yes, those are enabled in the route patterns
please always provide system and version info when posting the question
javalenc
if this helps, please rate
shikamarunara Tue, 04/08/2008 - 10:45
CUCM 6.X. The PIN is really just a series of digits that need to be entered 2 or 3 seconds after the call connects. Is there any way this can be done?
-Shikamaru
