7921 - roaming and registering issue
Apr 8th, 2008
I've a network with a lot of 7921 ( more than 50 ) connected to a lwapp wifi network:
- 7921 with 1.1.1 firmware
- wlc 4402 with 4.2.112
- ccm 6.0.1
- enabled WMM and CAC on controller
- Qos platinum ( for voice )
Does anyone had similar configuratio... with similar issue ?
Many thanks in advance
Luigi
tzunt Tue, 04/08/2008 - 18:58
Hi Luigi,
I'm working on similar a configuration (and issue). 150+ 7921s, same WLC, but CUCM 5.1.3. WMM & CAC.
I'm curious what type of APs you are using. TAC gave me some specific pointers for the type we have (Airospace 1000 series) which showed improvement.
I'd be happy to share them or discuss if you'd think it is relevant to your config.
Tony
LUIGI PIETRONAVE Tue, 04/08/2008 - 22:13
my ap are all 1242. I've seen some issue ( on the forum ) related to 1000 series... but i've 1242.
many thanks and regards
Luigi
